Wiki contribuído por estudante
Uma equipe incrível de estudantes do nosso programa de educação fez esta wiki.
The Headlight Will Not Work
The headlight will not turn on or off.
The Scooter Has Not Been Turned on
Make sure that you have turned the scooter on by holding down the red power button for three seconds located on the display on top of the scooter. If the display screen does not show anything, the scooter is off.
The Light Has Not Been Turned on
Make sure that you have pressed the button located on the front of the handle of the scooter.
The Light Switch is Defective
First, check that power is on. Press the button at least twice and observe if the light turns on and off. If the light shows no effect after pressing the light switch, consider replacing the button.
The LED is Faulty
The LED that produces the light may be broken. If this is the case, then consider replacing the LED. You can find a replacement guide here.
The Battery is Non-Functioning
If this is the case, then you should consider replacing the battery.
The Kickstand Will Not Support the Scooter
Scooter falls over when left without external support.
The Kickstand is Not Put down
You may not have put down the kickstand. Make sure that the kickstand is in a vertical position relative to the ground before letting go of your scooter to support itself.
The Kickstand is Wobbly
If the kickstand seems unstable and wobbles when left to support the scooter, consider replacing the pin that connects the kickstand to the platform of the scooter.
The Kickstand Will Not Go down
If the kickstand will not easily go down, consider applying lubricant to the hinge to pivot the kickstand easily.
The Kickstand is Broken
If the scooter falls over even when the kickstand is in the proper down position, the kickstand may be broken and not be the appropriate size to support the scooter. If you notice that the kickstand is significantly shorter than the size of a finger, consider replacing the kickstand.
Tire Will Not Spin
The tire will not rotate at full speed or will not move at all.
The Power Has Not Been Turned On
Make sure that the device has been turned on by pressing the button for three seconds located on the display on top of the scooter. If the display screen is blank, the scooter is off.
The Scooter is Not Moving when Throttle is Engaged
The scooter must be moving first before the motor will start producing power.
The Bearings Will Not Rotate
Bearings within the wheel allow for the wheel to turn. If they are seized and not turning, the wheel will not spin. To fix this problem, you should consider replacing the bearing held within the tire.
The Throttle Sensor is Faulty
If the sensor located within the throttle is malfunctioning and not responding to input by the rider, then check the wires leading to the sensor to make sure power is going to the sensor.
The Motor is Defective
Examine the wires inside the front tire and make sure that they are receiving power. If they are receiving power but the motor will still not rotate, considering replacing the motor. A replacement guide can be found here.
The Battery is Non Functioning
If this is the case, consider replacing the battery.
The Brake Will Not Stop the Scooter
The scooter will not slow down or stop when the brake is being engaged.
The Brake Pad is Worn Out
Examine the brake pad. If the pad is worn down, consider replacing the brake pad.
The Brake Switch is Not Functioning Correctly
If the brake pad is not worn out and the brake switch is not slowing down the scooter, consider replacing the switch. This brake switch replacement guide will show you how to replace the switch.
The Scooter Will Not Fold
The scooter does not collapse
The Release Lever is Not Pulled
Make sure the release lever is pulled before trying to fold the scooter.
The Release Lever is Stuck
If the release lever is stuck, make sure there is no debris blocking the action of the lever. If that is not the problem, consider applying lubricant to make the lever easier to pull.
The Folding Hinge is Stuck
If the folding hinge is stuck, make sure there is no debris blocking the movement of the hinge. If that is not the problem, consider applying lubricant to make the hinge easier to move.
293 comentários
The front tire doesnt want to spin and the speedometer is reading e1
jodheuakicklighter14 - Responder Compartilhar
I had the same error code on my transport and it was a wiring inside the wheel it was he rats nest and it was shorting out inside with every bump which causes the E1 message to flash and the scooter to shut down stop running and make a really annoying beeping sound that I had repaired and it works great now
jim reed - Compartilhar
HELP!!! Honestly I just bought this and it doesn’t work. I’m so !#^&@@! I did what they said and try to create a ticket and no one has called me back. I’m writing the Better Business Bureau first and honestly I think I’m gonna waste money and get a lawyer because this just isn’t fair and these people are making money off of us and getting away with it
jujuinflorida - Responder Compartilhar
Mine didn't work at first then i figured out if u take the screws out very carefully! The one usb cord wasn't plugged it.
Melissa Walters - Compartilhar
Itooms like we brought a right load of crap will try fix but eru doughtfiull
billboat10 - Compartilhar
