Ir para o conteúdo principal
Hover-1 Folding E-Scooter Brake Switch Replacement
O que você precisa
  1. Hover-1 Folding E-Scooter Brake Switch Replacement, Brake Switch: passo 1, imagem 1 %32
    • Twist the handle with the red level counterclockwise to remove it from the scooter's main body.
    • You will need to twist the handle clockwise reattach it to the scooter's main body.
  2. Hover-1 Folding E-Scooter Brake Switch Replacement: passo 2, imagem 1 %32 Hover-1 Folding E-Scooter Brake Switch Replacement: passo 2, imagem 2 %32
    • Remove the four 5 mm screws twisting counterclockwise with a Phillips #0 screwdriver.
    • These screws are small and easy to lose.
    • When inserting for reassembly the screws twist clockwise to secure.
  3. Hover-1 Folding E-Scooter Brake Switch Replacement: passo 3, imagem 1 %32 Hover-1 Folding E-Scooter Brake Switch Replacement: passo 3, imagem 2 %32 Hover-1 Folding E-Scooter Brake Switch Replacement: passo 3, imagem 3 %32
    • Remove the red brake switch by sliding it off the main body.
    • When putting the brake switch back make sure to align the tab with the throttle switch.
Conclusão
Brittani Kealoha
Membro desde: 10/08/18
251 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S15-G5, White Fall 2018 Membro de Cal Poly, Team S15-G5, White Fall 2018
CPSU-WHITE-F18S15G5
Membros da 4
Autoria de 5 guias
6 comentários
Do you know where I can find just the handle? They sent me a L and R but the L was stripped and won't screw in and the R will screw into both sides so I need either a L or R at this point I don't care i just can't find one and its “out of warranty”
Angela Renteria - Responder
Hi, I’m looking for a Hover-1 Eagle left handle?  Do you where can I find it? Thanks
Keila Talarico - Responder
looking for a new brake switch a hover-1 scooter,my grandson crashed and broke the brake switch. please help
Neal Weeks - Responder
Looking new break switch.where we will get?. please reply.
Vitesh - Responder
Looking for a throttle switch. Know where I can find one?
Mara - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 26
Últimos 30 dias: 34
Duração total: 4,909
