Ir para o conteúdo principal
Hover-1 Folding E-Scooter LED Headlight Replacement
O que você precisa
  1. Hover-1 Folding E-Scooter LED Headlight Replacement, LED Headlight: passo 1, imagem 1 %32 Hover-1 Folding E-Scooter LED Headlight Replacement, LED Headlight: passo 1, imagem 2 %32
    • Face the front of the scooter towards you.
    • Remove all four 24mm bolts by turning counterclockwise using the Hex 4 screwdriver bit.
  2. Hover-1 Folding E-Scooter LED Headlight Replacement: passo 2, imagem 1 %32 Hover-1 Folding E-Scooter LED Headlight Replacement: passo 2, imagem 2 %32
    • Remove the headlight housing.
    • The LED should release when you take off the cover.
    • Be careful when taking off the cover; the light is glued onto the cover and could harm the device.
  3. Hover-1 Folding E-Scooter LED Headlight Replacement: passo 3, imagem 1 %32 Hover-1 Folding E-Scooter LED Headlight Replacement: passo 3, imagem 2 %32
    • Disconnect the red wire using a soldering iron.
    • The soldering iron should melt the glue for you, so don't worry about removing it yourself.
  4. Hover-1 Folding E-Scooter LED Headlight Replacement: passo 4, imagem 1 %32
    • For ease of installation, tin your new LED and the connecting wire with the soldering iron and solder.
    • Solder your new light on to the existing red wire.
    • For help on how to solder, refer to iFixit's Soldering Guide.
Conclusão
To reassemble your device, follow these instructions in reverse order with the new LED.
Nicolo DiFronzo
Membro desde: 10/08/18
229 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S15-G5, White Fall 2018 Membro de Cal Poly, Team S15-G5, White Fall 2018
CPSU-WHITE-F18S15G5
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 21
Ao todo: 3,386
