Ir para o conteúdo principal
Ajuda
PAL Super Nintendo Teardown
Editando passo 2 —
Tipo de Passo:
Arraste para reorganizar
Remove the six screws located on the underside of the system with a 4.5mm Gamebit screwdriver.
Turn the unit back up and lift the top cover.
At the top is a capacitors shield. Make sure they're discharged before removing it. (Capacitors can hold charge for a long time, switching the power switch on while unplugged should discharge them)
This is the front panel, requires a ribbon cable to be unplugged.
This is part of the cartridge ejecting mechanism.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
