Ir para o conteúdo principal
Ajuda
Nintendo 2DS XL Teardown
Editando passo 1 —
Tipo de Passo:
Arraste para reorganizar
The battery is fairly easy to swap out once you remove the back cover.
The rear panel is secured by tri-point screws.
The headphone jack and charging connector are soldered to the motherboard.
The upper display is glued in place and requires prying that can potentially break the display.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
