Ir para o conteúdo principal
Ajuda
Withings Activité Pop Smartwatch Teardown
Editando passo 8 —
Tipo de Passo:
Arraste para reorganizar
This Withings Activité Pop Smartwatch had water ingress and it failed due to corrosion. A common fault with this watch is loose inner screws, leading to poor PCB contact with motors. When you change battery make sure you apply silicone grease on the rubber gasket of the case back. The dial and hands are not accessible since the glass is pressed.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
