Ir para o conteúdo principal
Ajuda
BLU Life One (2015) Teardown
Editando passo 4 —
Tipo de Passo:
Arraste para reorganizar
There will be 4 black screws you must remove from the plate that says NO HOT PLUG.
There is also 1 white screw. Make sure to only put this screw back in the spot from which it came. (Above the MicroSIM slot)
Using a pry tool, pry up from the lower right corner to release the snap connectors.
Keep prying the plate up and over the rear camera module to fully remove it.
4 Black Philips Screws
1 White Philips screw. Do not put this screw anywhere else but here!
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
