Ir para o conteúdo principal
Ajuda
Nintendo 64 Transfer Pak Teardown
Tipo de Passo:
Arraste para reorganizar
After the board is removed you can access the bracket that holds down the connector attached to the ribbon cable. You can remove this by unscrewing the screw on the bracket using a PH0 head
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
