Ir para o conteúdo principal
Ajuda
ANDIS CEC-100 Teardown
Editando passo 4 —
Tipo de Passo:
Arraste para reorganizar
What you will need to repair. Soldering Iron, paste flux and solder.
Next you will want to heat up your solder station and apply some flux to both the wire and the connector pin. I prefer to use Amtech flux however any flux is better then no flux.
Find a comfortable position that limits the amount of movement of both the wire and then switch.
Solder the wire to the pin.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
