Ir para o conteúdo principal
Ajuda
Xbox Series X Teardown
Editando passo 9 —
Tipo de Passo:
Arraste para reorganizar
Next, the meat of this board sandwich—the aluminum center chassis.
Its main purpose is to soak up High-Performance Gaming Heat™ (hence the bright minty thermal compound for the SSD and storage expansion slot).
Speaking of storage: the Series X uses an m.2 2230 NVMe SSD, namely a custom 1 TB SN530 by Western Digital. We heard it's super-fast PCIe Gen 4.0, too—this is high-end stuff!
Its nice to see Microsoft using a replaceable drive here, even if software barriers prevent you from doing the replacing.
Let's take a closer look at the bits that give this SSD its oomph (ignoring a pretty boring back side):
SanDisk 60662 1T00 1TB NAND Flash Memory
SanDisk 20-82-10048-A1 NVMe SSD Controller
Qorvo (formerly Active-Semi) 90430VM330 Power Management IC
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
