Ir para o conteúdo principal
Ajuda
OnePlus Nord Teardown
Editando passo 13 —
Tipo de Passo:
Arraste para reorganizar
The OnePlus Nord earns a 6 out of 10 on our repairability scale (10 is easiest to repair):
You only need one Phillips driver for any repair.
Almost all components are modular and can be individually replaced.
The battery can be replaced once you removed the motherboard shield. It’s only lightly adhered and comes with a pull tab for easy removal.
The primary access point for all repairs, the rear panel, is glued in place—but can be removed without heat.
Display replacements, which are the most common repairs, are not prioritized.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
