Pular para o conteúdo principal
Ajuda
Editando passo 22 —
Tipo de Passo:
Arraste para reorganizar
The SCSI devices are mounted on sleds. The sled can hold 3.5 inch and 5.25 inch devices.
Full-height devices can be accommodated but the bay above the bay in use will be inaccessible.
To remove a sled, slide the green lever to the left.
This sled holds the system disk, a 10k RPM 9GB Quantum. Slow and small by today's standard, it is typical for late 90s technology.
The sled's power connection.
Bus 0 connection (single-ended)
Bus 1 connection (differential signaling)
The Device ID can be set through a switch on the front panel. This switch plugs into the disk.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
