Ir para o conteúdo principal
O que você precisa
Vídeo de Apresentação
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Apple Watch Series 2, use o nosso manual de serviço.
  1. Apple Watch Series 2 Teardown, Apple Watch Series 2 Teardown: passo 1, imagem 1 %32 Apple Watch Series 2 Teardown, Apple Watch Series 2 Teardown: passo 1, imagem 2 %32
    • Our watches are getting smarter every day. Let's see what the newest generation of Apple wrist accessories has to offer:
    • Second-generation OLED Retina display with Force Touch
    • Consistent with the original Apple Watch, the Series 2 comes in two sizes: 38 mm (272 × 340 pixels, 290ppi) and 42 mm (312 × 390 pixels, 302 ppi).
    • Custom-designed Apple S2 SiP (System in Package)
    • Built in GPS + NFC + Wi-Fi 802.11b/g/n 2.4 GHz + Bluetooth 4.0
    • Accelerometer + gyroscope + heart rate sensor + microphone + speaker + ambient light sensor
    • Water resistance rating (up to 50 meters)
    • WatchOS 3
    What's between the sapphire crystal and OLED display?
    mark.albrechtsen - Responder
  2. Apple Watch Series 2 Teardown: passo 2, imagem 1 %32 Apple Watch Series 2 Teardown: passo 2, imagem 2 %32 Apple Watch Series 2 Teardown: passo 2, imagem 3 %32
    • With the release of the Apple Watch Series 2, the original Apple Watch has been replaced with the "Series 1"—a new model with a snappy dual-core processor.
    • The back of the Series 2 is adorned by a familiar quartet of optical polymer lenses protecting a set of LEDs and photodiodes.
    • Both series offer the same set of interchangeable bands for easy customization. If only every component could be this easy to replace...
    Actually, Apple Watch Series 1 has a dual core processor which the original Apple Watch didn’t have. So Series 1 is not the name for the old Apple Watch, but a new model.
    jannis - Responder
    This. Please pay attention to this, everyone. We need to remain aware of all attempts at companies and people trying to rewrite history.
    Dan Parsons -
    In the Original Apple Watch only the Stainless Steel model and the Edition (gold) model had a Ceramic back with sapphire lenses and the Sport edition had a composite back. Now all Series 2 models have a Ceramic back except the Series 1 model.
    bernardo - Responder
    This. Coming to see this. Please pay attention to this, everyone. All series 2 models is equipped with ceramic back. Even with aluminum case. That's the difference between series 0(composite back on aluminum), series 1(composite back), and series 2(all ceramic back).
    Denny Ken -
    Carry the same screen the series 1 and the series 2 42mm?
    Brn Ferreira - Responder
  3. Apple Watch Series 2 Teardown: passo 3, imagem 1 %32 Apple Watch Series 2 Teardown: passo 3, imagem 2 %32 Apple Watch Series 2 Teardown: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    iOpener
    $12.99
    Comprar
    • Armed with knowledge gleaned from the original Apple Watch and our expertise wielding an iOpener, we're ready to bust through the adhesive and pop off the screen.
    • Alas, as we pick up the display, we notice that the adhesive is much stronger than what we found in the 2015 model. We assume this change is for the purpose of added water resistance.
    • A knife, a pick, and a spoon full of gumption later and we're in!
  4. Apple Watch Series 2 Teardown: passo 4, imagem 1 %32 Apple Watch Series 2 Teardown: passo 4, imagem 2 %32 Apple Watch Series 2 Teardown: passo 4, imagem 3 %32
    • Externally, the Series 2 bears a strong resemblance to its older sibling—but once inside, we find a set of ZIF connectors in place of the awkward press connectors of yesteryear.
    • This refinement is great news for repair. Easily opened and secured connectors increase the likelihood of a successful fix.
    • And tucked away on the back of the display we find a whole host of control hardware:
    • Apple 343S00092
    • 20211CP TD1628A
    • NXP 67V04 NFC Controller (also found in the iPhone 7 Plus)
    Did you pop off a shield covering the discreet SMT's on the upper left? It also looks like you may have knocked two SMT's in the top left in heating up the shield.
    Also you may want to thin the color bands a bit so you can see the chips pins.
    Dan - Responder
    Please update this to show how to disconnect the ZIF connectors. I had to resort to just yanking them out and then shoving them back in, which seemed to not affect the display at first but after a day the screen is no longer working at all, so I’m guessing I destroyed the connectors and therefore the watch, permanently.
    Bryan Callahan - Responder
    Hi Bryan, thanks for repairing your Apple Watch Series 2. Unfortunately this (and any other) teardown is not meant to be used as a guide. But stay tuned, we’re in the process of preparing Series 2 guides (including the display). If you’re unsure about a connector in the future, you can look them up here: Recognizing & Disconnecting Cable Connectors
    Tobias Isakeit -
  5. Apple Watch Series 2 Teardown: passo 5, imagem 1 %32 Apple Watch Series 2 Teardown: passo 5, imagem 2 %32 Apple Watch Series 2 Teardown: passo 5, imagem 3 %32
    Mako Driver Kit - 64 Precision Bits
    $39.95
    Comprar
    • We slide the remaining band away from the body of the watch and start digging for the battery.
    • Just like the battery bracket in its cellular-capable counterpart, this piece is held in by a less-than-friendly tri-point screw. Thankfully, our 64 Bit Driver Kit is up to the task!
    • With a deft flick of our spudger this watch is rendered powerless.
    • Is it just us, or is this disassembly off to an easy start?
    So indeed according to the image the wifi antenna has moved to the right near the Digital Crown rather than the more familiar one we saw on the first generation on the top row just above the Taptic Engine and the speaker module
    yazdanbanaji - Responder
    Any information about the diagnostic port like the previous generations?
    Denny Ken - Responder
  6. Apple Watch Series 2 Teardown: passo 6, imagem 1 %32 Apple Watch Series 2 Teardown: passo 6, imagem 2 %32
    • Welp—as they say—if it seems too good to be true, it probably is.
    • Compared to last year's Apple Watch, the underside of the Series 2 battery reveals enough chewing gum adhesive to hold an iPad screen in place.
    • We hate to see this much adhesive on a tiny battery, but this time we'll give the adhesive on this swim-proof watch a break—after all, it lives on your wrist, not in your pocket.
    • We've never backed down from a sticky situation before, and this is no exception. We pick and prod, peel and pull the adhesive off the little power pack—with enough coaxing, it will come clean and reveal its secrets.
  7. Apple Watch Series 2 Teardown: passo 7, imagem 1 %32 Apple Watch Series 2 Teardown: passo 7, imagem 2 %32
    • With the glue stripped from the back of the battery, we get a closer look at its impressive specs. This cell is rated at 3.77 V and 273 mAh to yield a whopping 1.03 Whr of power.
    • Our watch is the 38 mm—the 42 mm should feature a larger power pack.
    • For those of you keeping score, this battery offers a full 32% increase in power over the previous generation—most likely to compensate for the addition of GPS capability.
    • Apple says the Series 2 will have about the same 18-hour battery life as the original Apple Watch, so that GPS must be power hungry.
    • One thing is for sure: this battery, like all batteries, will fail. And when it comes time to replace it, you'll be trading power for resistance—water resistance that is. When the seal is cracked on this watch, all the king's horses and all the king's men probably won't get it watertight again.
    I am glad the battery is bigger than the original Apple Watch. As a Pebble watch owner, I have been leery of the low battery life of the original Apple Watch. I would like to see a teardown of the new Apple Watch Series 1. I would like to see if the new battery in the Apple Watch Series 1 really is the same size as the new Apple Watch Series 2. (I know that the “published” battery life shows them with similar battery life's, but I take that published data with a grain of salt…) The GPS and water proofing of the Apple Watch Series 2 are not features that are particularly important to me, but battery life is. If the new Apple Watch Series 2 has a bigger battery than the new Apple Watch Series 1, that might make me look into the Apple Watch Series 2 (I’d keep GPS off), but if they both have the same battery, then I would lean toward the new Apple Watch series 1.
    Steven McDaniel - Responder
    Healthy dose of silicone sealant??
    gchesser - Responder
    Can you measure the dimensions of the battery and post them?
    Colby Bartholomew - Responder
    If you expect your watch to go 3 years between battery charges, you're not going to get it with a smartwatch.
    If you put your watch on the night stand / charger each night then the battery on the first generation was just fine. Mine still runs for about 43 hours.
    alex - Responder
    Alex how old is your battery?
    Mine is over 2 years, reports say battery still fine but it doesn’t take charge well and having issues updating.
    MrDazFlash - Responder
  8. Apple Watch Series 2 Teardown: passo 8, imagem 1 %32 Apple Watch Series 2 Teardown: passo 8, imagem 2 %32 Apple Watch Series 2 Teardown: passo 8, imagem 3 %32
    • Taking a plastic opening tool to the rim of the watch reveals a Force Touch sensor and gasket similar to the one found in the original model.
    • Like its 2015 counterpart, the Series 2 uses Force Touch to sense downward pressure on the screen. We first encountered Apple's use of this technology in the MacBook Pro 13" Retina Display.
    • Unlike last year's model, there's a lone IC hiding away on the Force Touch gasket:
    • Analog Devices AD7149 Capacitance Sensor Controller
  9. Apple Watch Series 2 Teardown: passo 9, imagem 1 %32 Apple Watch Series 2 Teardown: passo 9, imagem 2 %32 Apple Watch Series 2 Teardown: passo 9, imagem 3 %32
    • Next on our disassembly line is the noticeably larger Taptic Engine.
    • The Taptic Engine is Apple's take on the linear resonant actuator. It creates motion in a straight line (as opposed to the circular motion of an electric motor), which in turn provides haptic feedback.
    • The concept of a linear resonant actuator isn't unique to Apple devices. Pancake-shaped LRAs have existed in electronic devices for years—but the choice to utilize a rectangular z-axis LRA provides Apple with more design freedom and more control over how the user perceives the vibration.
  10. Apple Watch Series 2 Teardown: passo 10, imagem 1 %32 Apple Watch Series 2 Teardown: passo 10, imagem 2 %32
    • With the Taptic Engine extracted, we inspect the antenna module found tucked away at the top of the watch.
    • We suspect that the more complicated look of this small assembly is due to the addition of a GPS antenna. It is a tiny component, but the difference is notable when compared to the first Apple Watch.
    • What does GPS capability mean? It means this watch is only one step away from being an independent instrument of Pokemon Go—just as soon as it grows up and gets a real data connection.
    • Enough gawking—it's time to get our tweezers on what's left of this wearable.
    Any suggestion of whether the new antenna will give better wifi connectivity than the original had?
    Dan Martland - Responder
    where to order this part ?
    Dirk - Responder
    hi where can i buy this part?
    caiomarchi - Responder
  11. Apple Watch Series 2 Teardown: passo 11, imagem 1 %32 Apple Watch Series 2 Teardown: passo 11, imagem 2 %32 Apple Watch Series 2 Teardown: passo 11, imagem 3 %32
    • Hiding out on the outer rim, we find a complex cable assembly—home to the microphone and speaker.
    • And in between the two, the mystery of the second microphone port is solved. A flexible rubber plug looks like a barometric vent, designed to allow outside pressure to be felt by the internal barometer through the waterproof shell.
    • The Apple Watch Series 2 is trying to make a splash while keeping dry. This requires no shortage of gaskets and o-rings.
    • How well do these gaskets and o-rings keep water out? The Apple Watch Series 2 resists water intrusion to a depth of 50 meters, under ISO standard 22810:2010. This means it will be fine in a pool, but may fail during certain activities.
    "calls for hot tweezers" Are you sure you needed to pull this cable harness free? It appears the cables connection to the S2 was not designed to be disconnected as its part of the whole assembly of the S2 SIP unit.
    Dan - Responder
    Many watch sites, diving watches and otherwise, don't recommend taking any watch/electronics into a hot shower under pressure directed water. Or a hot bath. I know many plan to do exactly this every day.
    pswilson1 - Responder
    There's no barometer on the S2 though is there?
    iciclethief - Responder
    can this part be replaced? and whre can i order it?
    Dirk - Responder
  12. Apple Watch Series 2 Teardown: passo 12, imagem 1 %32 Apple Watch Series 2 Teardown: passo 12, imagem 2 %32 Apple Watch Series 2 Teardown: passo 12, imagem 3 %32
    • Did someone say ingress protection? This highly-touted speaker is equipped to deal with incoming water rather than fight it.
    • Unlike the original Apple Watch's speaker—which would simply flood when underwater—this module is designed to fill with water, then vibrate to pump excess water from the body of the speaker.
    • This pumping action, along with an automatic display shutoff, enables Apple Watch's swimming modes without risking damage to any critical components.
  13. Apple Watch Series 2 Teardown: passo 13, imagem 1 %32 Apple Watch Series 2 Teardown: passo 13, imagem 2 %32 Apple Watch Series 2 Teardown: passo 13, imagem 3 %32
    • There's one last piece barring us from reaching the belly of the beast: this ribbon cable assembly, where the Home Button and Digital Crown encoder reside.
    • Luckily, no teardown can be thwarted so easily. We quickly move past the gangly assembly to get at the core computer in this little wearable wonder.
    • And, in keeping with the tradition of last-minute tool modifications, we make use of our all new Apple Watch Opening Pick to lift the System in Package out of the rear enclosure.
    Am I the only one here who realizes that the button bellow digital crown is disappearing without any explanation how it looks when removed?
  14. Apple Watch Series 2 Teardown: passo 14, imagem 1 %32 Apple Watch Series 2 Teardown: passo 14, imagem 2 %32 Apple Watch Series 2 Teardown: passo 14, imagem 3 %32
    • And we finally reach the much awaited Apple S2 SiP—complete with the dreaded resin enclosure.
    • On the top of the SiP, tucked into the upper left corner, we spot a tiny pair of components:
    • Bosch Sensortec BMP280 Barometric Pressure Sensor
    • Likely an iteration of STMicroelectronics C451 gyroscope + accelerometer found in the original Apple Watch
    • But wait, isn't that the back? Where all the cables go? Turns out Apple decided to flip the SiP, so all of the connectors are on the same side as the things they connect to. Imagine that!
    Any reason why you guys did not open that shiny module? Would be interesting to see what kind of memory is in there as well as the application processor to memory interface.
    Denis Cabrol - Responder
    From the first Apple Watch Teardown: "Unfortunately, our first look is obstructed—that S1-emblazoned silver cap isn't a cap at all. It's a solid block of plasticky resin, hiding treasures deep within."
    This is what they were referring to as the "dreaded resin enclosure"
    Garrison Burger -
    That is not a second microphone, it is obviously a barometric pressure sensor from Bosch Sensortec
    Joe Ortaniak - Responder
    Apple don't claim the watch has a barometer. Does the tear down indicate it has one? Did the first watch have this component in it?
    Hi Dan, No the 1st Apple Watch doesn't have a barometer, but they learned that it is very important to get accurate calorie measurement, Additionally you get the absolute height and a weather station.
    carstenmichael97 -
    This is much neater than the original Apple Watch logic board. I'd be really interested to see a teardown of the new Series 1 watch. Did Apple update the internals of both models? The specs note an updated processor, so I think they did...
    Jamie - Responder
    Any thoughts on why the watch does not count stairs climbed despite the presence of a barometer?
    virtualshock - Responder
    It looks certain part like left side of middle area thinner than the other area. Is that any reason ?
    jiyoung chung - Responder
    you can mount a 38mm logic card in a 42mm housing
    rdcha - Responder
  15. Apple Watch Series 2 Teardown: passo 15, imagem 1 %32 Apple Watch Series 2 Teardown: passo 15, imagem 2 %32 Apple Watch Series 2 Teardown: passo 15, imagem 3 %32
    • All that's left between us and complete teardown glory is the sensor array, housed in the watch's back cover.
    • The four-sensor array includes infrared sensors, visible-light LEDS, and photosensors to track your heart rate throughout the day.
    • With the sensor assembly removed, we spy what we assume is the inductive charging coil left behind in the cover.
    • With the back cover removed, we get a glimpse of one last IC:
    • NXP Semiconductor Analog Front End Controller (likely)
    Did you just pop the rear lid off? No adhesive is used to hold it in place?
    That seems to impact the durability negatively, since if you drop it, the lid may just pop off.
    Tom Chai - Responder
    No adhesive this time? Is this snap-in like some manufacturers do with their traditional watches?
    lelandjordon - Responder
    Why the wireless charging IC Receiver did not mention in your teardown?
    rickchao1 - Responder
    How to get that sensor any idea guys!!
    Sariga K V - Responder
  16. Apple Watch Series 2 Teardown: passo 16, imagem 1 %32 Apple Watch Series 2 Teardown: passo 16, imagem 2 %32
    • And that's a wrap! With our Apple Watch torn asunder on the teardown table we step back to pick up the pieces—and hope it's still waterproof when we put it all back together.
    • We also want to take a second to thank our friends at Nikkei for joining forces and lending us some space in their Tokyo offices!
    lets hear how well you put humpty dumpty together again. Afraid it put it in a water bowl?
    But nice job, well photographed, very informative.
    Who laid out the $400 for a teardown?
  17. Considerações finais
    • While not an industry standard, the watch band is easily removed and swapped out for a replacement.
    • Removing the screen is difficult, but not impossible—it's the first component out, and is connected with easy to use ZIF connectors.
    • Once you're inside, the battery is fairly easy to remove—if you have the proper tri-point Y000 driver.
    • While not proprietary, incredibly tiny tri-point screws are a repair hinderance.
    • Replacing any of the component cables requires microsoldering—but does not require removing the SiP as in the previous generation Apple Watch.
    • The fully encased S2 system makes board-level repairs impossible.
    Índice de reparabilidade
    6
    Reparabilidade 6 de 10
    (10 é o mais fácil de reparar)
56 comentários
Here we go ....! The best part of staying up late is to be the first to get hands on teardown these little monsters packed with loads some of the most intricate and advanced pieces in tech manufactured to date
Hmmm... does this mean the Apple Watch might actually be repairable by repair shops? The display looks a lot easier to take apart. Minus the likelihood that repairing it may render it not "swim proof" anymore.
Kevin Stuckey - Responder
True I've had loads of issues before while repairing the Apple Watch specially with the glue that becomes almost useless the minute you pop the screen off and not to forget the tiny metal bracket holding the display and digitiser flex in !! This indeed looks repairable
yazdanbanaji -
I've never repaired it, but I was warned not to. Perhaps now this will change with a few ZIF connectors.
Kevin Stuckey -
It isn't as easy as it looks ! I was warned by many too ....I infact ripped one of my first motherboard flex cables off in the past ...by curiosity didn't stop me ! You always get it right the next time ! I'd suggest on picking up one of the demo units from eBay to try your stunts right as they are as low as $100 to see your first teardown come off and then you can repair your customers watches easily after you tear one down for yourself
Great idea! I definitely need to pick one up first to test it myself.
Kevin Stuckey -
I'll have to wait for a month atleast before I can get my hands on ! Moreover the 2nd gen ones will be out late on eBay ...! And the shipping could take ages if your not in the states but it's worth it still
Does it have the same diagnostic port Apple Watch Beta had?
Rishi Oswal - Responder
Does it have a second mic? Or anything changed about the mic?
Siri on Watch works much less well than Siri on iPhone, and I suspect it is primarily a mic issue.
name99 - Responder
What is the available onboard storage for music on the series 2?
hifial - Responder
According to settings it can store up to 2gb of songs
Pankaj Balegar -
Jesus! The capacitor in step 4 picture 3 on the right is nearly falling off! Quality control is minimal here!
fraserkillip - Responder
the question is how was the metal shielding removed. If you see earlier photos, those areas were protected. Those protection needs to be removed before 3rd photo could be taken. If excessive heat was applied, of course the solders holding those components would melt, causing them to look like that.
Chris Quek -
Yes, we had to desolder the metal shield. That damaged some components underneath. If you've got a better technique for removing these shields, we're all ears!
Kyle Wiens -
Kyle Wiens I'd love to see you guys teardown the S2 from the metal housing if that's a possible ! I know it's a destructive process at times but if you could I'd be greatful
See Step10, there is an amazing multi-pin connector!
Does anyone know who is the supplier of this connector?
Vitexia Gan - Responder
Maybe the connector is from murata!
Sarah yang -
Hey you might wanna double check, the new series 2 with aluminium are listed as having a ceramic back. An upgrade from the polymer back on the apple watch sport.
Eivie - Responder
And where's the "service port"? no word about it...
barrerafacundo - Responder
What about the second mic hole> Not found on the original Apple Watch!
Alex Smith - Responder
Could you measure the dimensions of the Apple S2 System in Package? That would be very useful for analysis of the system. Also, high-res photo's of the S2 (especially without the metal lid) would be much appreciated :)
Ewout - Responder
I wonder, they mentioned the series 1 will get the dual core CPU, but not if the GPU and the rest of it were the same. Are they?
That's probably a question that' down to Chipworks. And how about RAM?
tipoo - Responder
Zone of Tech says it has 1GB of system ram up from 512MB in the original models.
Taylor Barcroft -
I want to buy one.
Michael Lin - Responder
Does it still have the little external service port? I don't see it in this teardown.
strells - Responder
I've been trying to get that info, and nobody from iFixit or anywhere else for the matter is able to reply...
barrerafacundo -
My series 2 has some little doors in the same place as the first generation, however it looks smaller this time - it is smaller in length than the button for band release...
Lenka Minarikova -
Afew weeks ago I bought on flea-bay a "Smart Watch" for all of 16 GBP - this has a removable battery and provision for a SIM card and extra memory micro-SD, so is a true "Wrist Communicator" - (and if you don't know what that means look up Dick Barton !).
So this cheap Chinese watch goes further than Apple - and does a variety of things; above all is the ability to dispense with a paired phone. It is called "APLUS" and I have no connection with the seller other than being a satisfied user.
How do the Chinese do this so cheaply; how long before Apple will offer an internal SIM ?
danmdan - Responder
Has the hear rate sensor changed from 2015?
Pete - Responder
Last time the prototype Gyro was published as InvenSense. That was a good guess based on the fact InvenSense is Apple's go to company for motion technologies. But it ended up being STM. That was because STM was first there in the original design.
Now the guess is "Likely an iteration of STMicroelectronics C451 gyroscope + accelerometer". Based on the fact STM was in on iWatch1. But the iWatch2 has diiferent requirements. This gyro must provide a navigation solution and turn off the power hungry GPS 80% of the time. InvenSense excells in this capability.
I would be highly surprised if InvenSense does not have the best 6 axpoThe real question in my mind is did Apple use InvenSense Software? If so better margins should be coming.
KrisCo - Responder
Is the Heart Rate sensor an upgrade from the previous model? Any part numbers on there at all?
Mick Wall - Responder
"The fully encased S2 system makes board-level repairs impossible."
you cannot be serious.
The improved reliability afforded by the resin encasement is vastly more important that the tiny probability that anyone would ever successfully perform a board level repair, even without the resin.
alex - Responder
How much RAM inside Apple Watch 2?
williamfe - Responder
Any dimensions on the separate items? Apple hasn't released a spec sheet yet... (Case, Top Glass, Port Locations...)
bwines - Responder
How much storage does it have??
Borompanha Mao - Responder
According to the info in Settings -> About in the watch Series 2, 38mm, it has 5.7 GB internal capacity.
Lenka Minarikova -
Does anyone know, who supplied the PPG tech for the Heart Rate sensing capabilities?
design8a - Responder
Apple 343S00092 is a dialog semi PMIC
whiteriver - Responder
Can you comment on this additional seam that can be found on this Reddit thread? https://www.reddit.com/r/AppleWatch/comm...
Alistair Calder - Responder
Last time you reported the original version had a pulse oximeter. Has it been removed for this iteration?
Steve - Responder
Anyone knows how the antennae RF connections are done?
Nelson Young - Responder
Is there an improvement in the heart rate sensor? I know I'm my Apple Watch Series 1 (sports version) it seems a little slow to pick up my heart rate and also refresh when I begin exercise. Anyone know how often it 'refreshes' also?
MrMinorDetail - Responder
hey, do you have any ideea is the sapphire led display from series 1 compatible with series 2 ? somehow I broke mine and i can't seem to be able to find one to buy and I'm still trying to avoid the apple store since it was a gift and haven't got applecare+ for it ...
webstefan2003 - Responder
Hello, I have an Apple watch 42 mm the first model q was released. It was working normal and suddenly started to restart and stay in that infinite lopp. Is there anything that can be done to reverse this situation?
bruninhoguaragni - Responder
Wonder what happened with the barometer. Maybe they disabled it last minute to save on battery.
Cory Mayer - Responder
What 38mm apple watch parts can be used in the 42mm? Can I put the 38mm SIP S2 in the 42mm or the reverse?
Gasol - Responder
Hi, is the apple watch series 1 and series batteries interchangable ?
Mishalin - Responder
CORRECTION: Hi, is the apple watch series 1 and series 2 batteries interchangable ?
Can we remove and replace the glass from the lcd as per series 1?
Les Bills - Responder
@kyle
In regards of how to remove the shielding without suffering component damage, you could physically cut it off. I did that with an iPhone 5 logic board, although it damaged some coils. There must be a more precise way to machine it off.
Liam Powell - Responder
Hi guys. Excelent tear apart guide. Just wanted to ask if by replacing the screen on the watch series 2, is there any way to get the watch sealed again so one can swin with it with no problems?
Juan Carlos Linares - Responder
I would love to see some detailed photos of the chips on the motherboard - to get an understanding of the specs of the components - GPS, Motion detectors, memory, CPU etc.
Alan Smith - Responder
That’s a little beyond iFixit’s abilities in a case like this, but our friends over at TechInsights have taken it a lot further.
Jeff Suovanen -
Although board level repairs aren’t viable, is it possible to replace the board of an apple watch? When putting the watch back together, did it still seem waterproof?
Logan Jung - Responder
My apple watch display broken so I replaced my watch display but now watch can’t pair to my phone what is the reason why my watch not pair to my phone
Sam shakya - Responder
Someone tell me about where can i buy back aluminium cover (sideral grey/nike edition) replica of apple iwatch series 2 (42mm)?
Federico Gregori - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 45
Últimos 30 dias: 251
Duração total: 262,855
