Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Apple Studio Display M2454, use o nosso manual de serviço.
  1. Apple Studio Display M2454 Teardown, Apple Studio Display M2454 Teardown: passo 1, imagem 1 %32
    • Notice that the main components of the monitor are only accessible from the back of the device.
  2. Apple Studio Display M2454 Teardown: passo 2, imagem 1 %32
    • Locate the four hex head screws located on the corners of the back panel.
    • Remove the screws with a 2mm hex screwdriver.
  3. Apple Studio Display M2454 Teardown: passo 3, imagem 1 %32
    • Remove the clear and gray back panels.
  4. Apple Studio Display M2454 Teardown: passo 4, imagem 1 %32
    • Remove the three screws with #2 phillips head screwdriver.
  5. Apple Studio Display M2454 Teardown: passo 5, imagem 1 %32
    • To remove the metal panel, push towards the bottom of the monitor to release its clips and pull the panel away.
  6. Apple Studio Display M2454 Teardown: passo 6, imagem 1 %32
    • Remove screw holding the plastic bracket with #2 Phillips head screwdriver.
  7. Apple Studio Display M2454 Teardown: passo 7, imagem 1 %32
    • Remove the four screws on the metal bracket.
  8. Apple Studio Display M2454 Teardown: passo 8, imagem 1 %32
    • Remove the two philips head hold-down screws with the #2 Phillips head screwdriver.
  9. Apple Studio Display M2454 Teardown: passo 9, imagem 1 %32
    • Remove black connector by pushing the end of the tab closest to the wiring and pulling away from board.
  10. Apple Studio Display M2454 Teardown: passo 10, imagem 1 %32
    • Remove white connector by lifting tab and pulling away from board.
    • Be careful when lifting tabs, they break easily.
  11. Apple Studio Display M2454 Teardown: passo 11, imagem 1 %32
    • Remove connector connected to the hold down previously removed simply by pulling with hand.
  12. Apple Studio Display M2454 Teardown: passo 12, imagem 1 %32
    • Now that the main computer cable is detached, remove it away from monitor.
  13. Apple Studio Display M2454 Teardown: passo 13, imagem 1 %32
    • Remove the two screws holding the USB port in place with #2 Phillip's head screwdriver.
  14. Apple Studio Display M2454 Teardown: passo 14, imagem 1 %32
    • Remove the screw on the wire hold down with #2 Phillips head screwdriver.
  15. Apple Studio Display M2454 Teardown: passo 15, imagem 1 %32
    • Remove white connector connected to LCD main board by lifting tab with tool and pulling away from board.
  16. Apple Studio Display M2454 Teardown: passo 16, imagem 1 %32
    • The USB port is now detached, remove it from monitor.
  17. Apple Studio Display M2454 Teardown: passo 17, imagem 1 %32
    • Remove connector on the left bottom corner of the LCD main board by simply pulling with hand.
  18. Apple Studio Display M2454 Teardown: passo 18, imagem 1 %32
    • Remove the connector on the bottom right corner by 1st removing tape first and pulling with hand.
  19. Apple Studio Display M2454 Teardown: passo 19, imagem 1 %32
    • Remove top right connector of the LCD main board by pulling with hand.
  20. Apple Studio Display M2454 Teardown: passo 20, imagem 1 %32
    • Remove the final connector of the LCD main board by pulling with hand.
  21. Apple Studio Display M2454 Teardown: passo 21, imagem 1 %32
    • Remove the four screws on each corner of the main board with #2 Phillips head screwdriver.
  22. Apple Studio Display M2454 Teardown: passo 22, imagem 1 %32
    • The board is now detached, remove it from monitor.
  23. Apple Studio Display M2454 Teardown: passo 23, imagem 1 %32
    • Locate the top and bottom connector on the CCFL inverter and remove it by inserting pin into the small holes and pulling away.
    • This step may be easier with two people.
  24. Apple Studio Display M2454 Teardown: passo 24, imagem 1 %32
    • Remove the two screws on the top and bottom of the CCFL inverter with #2 Phillips head screwdriver.
  25. Apple Studio Display M2454 Teardown: passo 25, imagem 1 %32
    • The CCFL inverter is now detached, remove it from monitor.
  26. Apple Studio Display M2454 Teardown: passo 26, imagem 1 %32
    • You have now successfully taken apart a Apple Studio Display M2454.
Dylan Perry
Membro desde: 01/20/10
177 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 13-27, Maness Winter 2010 Membro de Cal Poly, Team 13-27, Maness Winter 2010
CPSU-MANESS-W10S13G27
4 Membros
Autoria de 9 guias
3Comentários do guia
This model is also known as the Apple Studio Display 15" LCD.
analogcd - Responder
excellent wee guide......i came here in my search for a replacement stand for this model.
bobby nailen - Responder
Failing caps were the main problem with this — no air flow.
Mal - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 40
Ao todo: 7,797
