Ir para o conteúdo principal
« Voltar para Todas as Histórias
Great Tutorial!
ifurybeat -
iMac Intel 21.5" EMC 2428
Imagem da história
Installing iMac Intel 21.5" EMC 2428 Dual Drive Kit
1 - 4 horas
Difficult
Meu Problema
I added a SSD drive to it and replace the optical drive with a new one.
Minha Solução
It went well except i forgot to remove the ir sensor before i pulled out the logic board so it was little bit tricky to put it back inside :)
An unknown cable unplug itself when i put back the logic board. I was lucky enough to look at the tutorial pictures to know where it was plugged before (the one near the optical drive fan slot).
Meu Conselho
Be careful to not unplug the cable in the picture when you put back the logic board because it can get stuck easily in the screw hole of the logic board.
Imagem de iMac Intel 21.5" (Mid 2011) Dual Hard Drive Kit
$27.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Ao todo: 64
