Ir para o conteúdo principal
« Voltar para Todas as Histórias
iPhone 4 Home Button replacement
stefan -
iPhone 4
Imagem da história
iPhone 4 Home Button Replacement
2 horas
Difficult
Meu Problema
The Home Button did not work properly.
Minha Solução
I had about 2 hours to replace the home button and again a half hour to test all functions, because it was not my own phone.
I also cleaned the inside of the phone from dust.
Everything works fine and the owner is now very happy ;-)
Meu Conselho
I had little problems with putting back in the logic board. Just put in first the bottom side (where the loudspeakers are) and then the top, then it's not a problem. Or just think before you try ;-)
Imagem de Spudger
Spudger
$3.99
Imagem de Mako Driver Kit - 64 Precision Bits
$39.95
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 19
Ao todo: 60
