Ir para o conteúdo principal
« Voltar para Todas as Histórias
The Dreaded Track Pad & Keyboard Failure
paulxpac -
MacBook Core Duo
Imagem da história
MacBook Core Duo Upper Case Cable Replacement
Moderate
Meu Problema
My MacBook (Model 1181) is in pristine condition, so getting a new one seemed wasteful. After doing an internet search on possible causes of intermittent track pad and keyboard failure, I found it to be a consistent problem with these models. I ran thru the prescribe checks and decided to change out the upper case cable instead of the whole upper case, $30.00 vs. $150.00 plus.
Minha Solução
As with all thing electrical, sometimes connections need to be reseated, particularly in humid environments. This combined with warm up and cool down of the computer, over time connections may fail. I replaced the cable for good measure which corrected the problem.
iFixit's repair manuals are great. Following the step by step instructions and using the right tools, makes changing parts a breeze. With every Mac I buy, I at least keep a copy of certain iFixit repair manual for emergency use. Thanks, iFixit.com!!!
Meu Conselho
Hint: I placed double stick tape on some paper and place my screws in order of removal on the tap. I also made any notes to myself where needed. This made it exceptionally easy to find the right screw for the right hole on reassembly.
Imagem de MacBook Upper Case Cable
$24.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 265
