Ir para o conteúdo principal
« Voltar para Todas as Histórias
Smashed and shattered
brook -
iOpener
Imagem da história
iOpener Instructions
30 segundos
Easy
Meu Problema
To expensive to buy new, cheaper to replace broken part.
Minha Solução
Without the iOpener it was a fricken nightmare!!! You could over heat the unit with a heat gun and have to buy a new unit or use the iOpener and get it done in about a half hour, just like it says before you buy it. The glass stays together better, even where it is cracked when removing. Great tool, very simple and yet very effective.
Meu Conselho
Before you even try to remove an iPad glass, jut spend the $20 you will be very glad that you did. Also this nifty tool can be use on all sorts of different units. You will definitely make your money back.
Imagem de iOpener
iOpener
$24.95
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 60
