Ir para o conteúdo principal
« Voltar para Todas as Histórias
Absolutely Beautiful
Chad Whitaker -
iPhone 4
Imagem da história
iPhone 4 Rear Panel Replacement
2 - 5 minutos
Easy
Meu Problema
A crack down the back of my iPhone 4 led me to look into purchasing a replacement.
Minha Solução
The transparent back is delightfully geeky. Repair is as simple as can be. Two screws, slide the back off, slide the new back on, two screws. Done. Seeing the iPhone 4's guts through the transparent back is absolutely beautiful.
Meu Conselho
There is a small "sticker" on the back of the Apple iPhone 4 back, with a small contact spot on it. I had believed that this was part of the antenna assembly for the iPhone. (Not sure if it's for Bluetooth, Wi-Fi, 3G?) In iFixit's own words, "You can also see pressure contact on the inner face of the rear panel for what appears to be an antenna." I haven't noticed any issues so far, but I don't use Bluetooth and I'm rarely on the phone. . .
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 13
Ao todo: 77
