Ir para o conteúdo principal
« Voltar para Todas as Histórias
Fixing the devastating Custom OS screen.
Kyeler W -
Samsung Galaxy A14
Imagem da história
  • Imagem #1
  • Imagem #2
Samsung Galaxy A14 Screen Replacement
25 minutos
Moderate
Meu Problema
After moving my internals to the new casing, I keep encountering this screen (second image) after connecting the battery to the motherboard. The volume button would not detect the right input. I cleaned the volume buttons multiple times and nothing worked.
Minha Solução
I figured out the problem. My new casing didn't have the part in the square glued to the case, it was lifted up and flopping around. It took me a while to realize, but it isn't supposed to be on top of the motherboard; it's supposed to rest under it.
Meu Conselho
Make sure everything looks in place and compare it to your previous casing; you might save yourself the 20 minutes I sacrificed to fiddling around with volume buttons.
1 comentário
good job dear
Sara Mah - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Ao todo: 305
