Ir para o conteúdo principal
« Voltar para Todas as Histórias
iPhone 15 Battery Replacement
Kalie Brunton -
iPhone 15
Imagem da história
2 horas
Moderate
Meu Problema
The phone was dropped and the back glass cracked and also damaged the battery, which was swollen.
Minha Solução
The battery repair went smoothly. It took under an hour, including the time to separate the back glass from the screen.
Meu Conselho
Sometimes the batteries (the originals especially) can be a pain to remove from the phone. The adhesive is no joke. I use an iFixit iOpener to lay over the battery and heat up the adhesive, and then use an opening pick to pry it up. Slow, consistent pressure is the way to go.
Imagem de iOpener
iOpener
$24.95
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 17
Ao todo: 148
