Ir para o conteúdo principal
« Voltar para Todas as Histórias
Ring gen 2 repair
Clutha -
Ring Video Doorbell
Imagem da história
Ring Doorbell 1st Generation Battery Replacement
40 minutos
Easy
Meu Problema
Our door bell failed and on inspection the battery charging socket looked contaminated by moisture. I cleaned it but the unit would only stay online for about an hour then indicated loss of WiFi
Minha Solução
Investigation went well using the guide on removing case.
I noticed the mesh indicated in the picture was displaced and not making contact with plate below it. On pressing it down it seemed to have adhesive on it to hold it in place. When closing the case I put two small pieces of thin packing foam on top of mesh to hold it down. Cover replaced and unit left online in house to help dry out any moisture. We’ve had storms & heavy rain humidity over 95%
Unit was ok for 3 hours so refitted outside
It has been 0degC overnight and it’s still working!
Meu Conselho
You must have good small screwdrivers for case screws, a work mat that holds removed parts
3 comentários
This is good, I will save it for future reference.
Ravikant - Responder Compartilhar
Sounds good, it is very helpful.
Shower - Responder Compartilhar
Thank you for this helpful guide!
Juan Colon - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 16
Ao todo: 423
