Ir para o conteúdo principal
« Voltar para Todas as Histórias
Easy peasy upgrade
Almond McClain -
Steam Deck
Imagem da história
Steam Deck SSD Replacement
2 horas
Easy
Meu Problema
it was actually an upgrade. hardest part was cloning the drive, which took overnight. actual swap of the drive took maybe 15 minutes, and it worked perfectly.
Minha Solução
I can't believe it went so smoothly. With all the trouble I've had repairing older portable consoles and last few years I was expecting the worst. least amount I've worked on a portable with the most amount of gain.
Meu Conselho
take your micro SD card out BEFORE you dare take the rear cover off
Imagem de Steam Deck SSD
Steam Deck SSD
$161.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 182
