Ir para o conteúdo principal
« Voltar para Todas as Histórias
Joycon Drift Repair
Gwen Sanchez -
Joy-Con
Imagem da história
Left Joy-Con Joystick Replacement
30 minutos
Moderate
Meu Problema
My left joycon was experiencing really bad controller drift. It started off very minor but eventually it became so bad that I avoided playing certain games until it was fixed.
Minha Solução
The repair went well! I followed the guide available on ifixit and it was easy to follow. Took about half an hour to replace the joystick.
Meu Conselho
Remember to calibrate your joycon after the repair is done!
Imagem de Nintendo Switch Joy-Con/Switch Lite Joystick
$14.99
1 comentário
Waste of money/warranty - all you need to do is to tilt the joystick and give it a squirt of WD40 Contact Cleaner, rotate it a bit and calibrate if needed. No dissassembly or parts needed other than that can.
Peter Jensen - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 18
Ao todo: 822
