Ir para o conteúdo principal
« Voltar para Todas as Histórias
iMac SSD Upgrade
Carl Hill -
iMac Intel 27" EMC 2639
Imagem da história
  • Imagem #1
  • Imagem #2
  • Imagem #3
iMac Intel 27" EMC 2639 Hard Drive Replacement
2 horas
Moderate
Meu Problema
The oem 2TB HDD was just full and unable to boot. Opted to upgrade to SSD and reinstall OS.
Minha Solução
Everything well very well. The kit was well worth the money as I likely would have failed without it. The new adhesive is easy to work with, the foam brace makes things easy and the SSD Temp sensor likely would have been forgotten if I hadn't just purchased this kit.
Meu Conselho
Removing the screen can be tricky but just keep cutting and prying gently and slowly and it will come out. Removing and routing the cables around the HDD can be tricky but again just don't force anything and be patient.
Imagem de iMac Intel 27" (Late 2012-2019) SSD Upgrade Kit
$115.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 270
