Ir para o conteúdo principal
« Voltar para Todas as Histórias
Successful MacBook Pro right speaker replacement using iFixit replacement
Richard Cox -
MacBook Pro 15" Retina Display Mid 2015
Imagem da história
MacBook Pro 15" Retina Display Mid 2015 Right Speaker Replacement
2 horas
Moderate
Meu Problema
Rights speaker developed distortion...sounded like a perforated speaker cone...
Minha Solução
Straightforward but fairly lengthy mainly due to logic board removal
Meu Conselho
Have right tools (pentalobe, torx screwdrivers, spudger assortment)
Use air duster throughout to clean out dust from fans and between board
layers as you go...also isopropyl alcohol on Q tip here and there.
The advice about avoiding trapped connectors when replacing logic board
was well heeded but even so careful checks needed.
Useful tools - pentalobe screwdriver, torx screwdrivers, iFixit magnetic parts mat, binocular magnifier
clip-on for spectacles (purchased years ago from Tokyo Hans store in Akihabara district, Tokyo)
Imagem de MacBook Pro 15" Retina (Mid 2012-Mid 2015) Right Speaker
$29.99
1 comentário
Hi Richard, Looks like there is a flaw with these speakers. I’ve got same mid 2012 model. Some time ago the right speaker went crazy like yours did, so I turned it off and used only left speaker. And last week same happened to left speaker, so I decided finally to order R and L speakers. I am not sure yet if I do the repair myself, reading the tutorial it seems easy to ruin some connections.
chirolob - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 15
Ao todo: 288
