Ir para o conteúdo principal
« Voltar para Todas as Histórias
iMac (Mid 2011) SSD Install
justincarver -
iMac Intel 21.5" EMC 2428
Imagem da história
Installing iMac Intel 21.5" EMC 2428 Dual Drive Kit
1 hora
Moderate
Meu Problema
Slow performance using the original 1TB 7200 RPM hard disk. Installed a 500 GB WD Blue SSD to work alongside the HDD (custom Fusion Drive).
Minha Solução
Process was simple. Remove screen, remove superdrive, remove mainboard, install SSD and necessary cables, and reinstall. No issues whatsoever.
Meu Conselho
Take your time, take photos if necessary for reference, and be gentle on all the small plastic connectors. Get a can of compressed air while everything is apart and give it a complete cleaning before you reassemble.
Imagem de iMac Intel 21.5" (Mid 2011) Dual Hard Drive Kit
$27.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 20
Ao todo: 481
