Ir para o conteúdo principal
« Voltar para Todas as Histórias
Digitizer disaster
Ken Spires -
iPad Air Wi-Fi
Imagem da história
iPad Air Wi-Fi Front Panel Assembly Replacement
2 horas
Moderate
Meu Problema
It was cheaper to fix than replace, plus I LOVE a challenge.
Minha Solução
I was a little nervous. I have replaced several iPhone screens, but this was my first iPad. Clear a spot at a bench, spread out a darker colored (lint-free) fabric. I use dark so that tiny screws, etc. will stand out. Also, if you have access to an anti-static mat, that is better.
Meu Conselho
If you are not using an anti-static mat, be sure anytime you let go of whatever you are working on, you ground yourself to the metal frame before proceeding. Do not rush, follow instructions, BE GENTLE! I used clear packing tape to keep the digitizer together while working with it. It also kept small shards from sticking out and cutting me. Use clear tape so you can still see the LED display. Be diligent when cleaning old glass and seal fragments. Be patient.
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 21
Ao todo: 122
