Ir para o conteúdo principal
« Voltar para Todas as Histórias
The Growing Power Problem
Scott Stuck -
MacBook Pro 13" Unibody Mid 2012
Imagem da história
MacBook Pro 13" Unibody Mid 2012 Battery Replacement
5 minutos
Easy
Meu Problema
As you can see from the photo, my old battery decided to hit puberty and started growing. To my surprise, the existing home we provided for that battery was too small. As a result, it decided to grow through the trackpad as quickly as possible.
Minha Solução
This was a super easy repair, albeit slightly scary because I was waiting for the battery to spontaneously combust. Simple removal of screws, one plug, then repeat in reverse order.
Meu Conselho
None. If you are scared about doing a repair like this, don't worry. It is super easy and quick to do.
Imagem de MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Battery
$80.99
1 comentário
Hi Scott - Mine has grown through the trackpad as well. Did you end up replacing the trackpad or just the battery?
Kartic - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 571
