Ir para o conteúdo principal
« Voltar para Todas as Histórias
2011 iPhone 4s First-Time Battery Replacement
Leandro de la Rosa -
iPhone 4S
Imagem da história
iPhone 4S Battery Replacement
3 horas
Moderate
Meu Problema
The battery's lifespan has severely degraded after 7 years. The indicator gets stuck on 1% for a long time.
Minha Solução
It went well with the exception of the removal of the 1.7 mm Phillips screw by the battery connector. The reason it took my battery replacement process 3 hours is that I stripped the aforementioned screw. The included iFixit screwdriver's Phillips screw attachment for reason didn't go well with the 1.7 mm screw. After I miraculously removed the stripped screw, everything else went without a hitch.
Meu Conselho
Don't strip any screws. If you think you are careful during the unscrewing process, you should probably be a little bit more careful.
Imagem de iPhone 4S Battery
iPhone 4S Battery
$18.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 14
Ao todo: 233
