Ir para o conteúdo principal
« Voltar para Todas as Histórias
EASY AS 1.. 2... 3 !! Thank you
Steven Coffey -
iPhone 6
Imagem da história
iPhone 6 Battery Replacement
30 minutos
Moderate
Meu Problema
My device's response time was diminishing.
Minha Solução
Easy as 1.. 2.. 3 !
Largest obstacles were adhesive strips employed to anchor battery to backplate.
Utilized hair dryer (heat) that made adhesive strips more pliable which resulted in a clean removal.
Secured display to box instead of fully removing it.
Meu Conselho
Anchor display to packaging to avoid interaction with as many connections as possible.
Heat the back plate of the phone first to make adhesives more pliable.
Use of FLAT tip tweezers from medicine cabinet to manipulate adhesive from the underside of installed battery, keeping strip taught.
Imagem de iPhone 6 Battery
iPhone 6 Battery
$29.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Ao todo: 110
