Ir para o conteúdo principal
« Voltar para Todas as Histórias
iPod mini replacement gone awry
Colin Szechy -
iPod Mini
Imagem da história
  • Imagem #1
  • Imagem #2
iPod Mini Battery Replacement
30 minutos
Moderate
Meu Problema
My iPod mIni's battery was dying, and I wanted to replace it to get more life out of it.
Minha Solução
Not well. The two screwdrivers (#00 Phillips and a flathead) look to be decent. It was a little hard prying out the white tabs, but after that, disassembly was easy.
THE BATTERY THEY GIVE YOU IS LARGER THEN THE ORIGINAL. That's worked out okay for most of the repair stories I've seen, but not this one. When I went to put the entire assembly back in, I wasn't careful enough and the battery was struggling to fit... resulting in a component giving in. Namely, I cracked my screen. Don't know how to repair that one.
The bit around the crack still works at least... bleh.
Meu Conselho
Be careful about putting the whole assembly back in
1 comentário
Hope it goes well:)
HolishXXX - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 122
