Ir para o conteúdo principal
« Voltar para Todas as Histórias
If it fails, try again
Tim -
iPhone 6s
Imagem da história
iPhone 6s Screen Replacement
10 minutos
Moderate
Meu Problema
As we all know, dropping your phone is going to happen, period. My screen is cracked due to a drop. Still functional, but annoying.
Minha Solução
Ordered my part from iFixit, arrived in less than 5 days. Followed the easy directions for the tear-down. Everything was fine, assembly was just as easy. Power up, touch screen doesn't work as I cannot enter my unlock code. Maybe I missed something, cable not seated correctly, tear-down again. Reassemble.....nope. Forced a power down since the "swipe" feature also didn't work to power off. Waited a few seconds and powered back on. Touchscreen still unresponsive. Called up iFixit, explained the issue and troubleshooting steps taken, they immediately re-issued another replacement. Two days later, start the repair again....SUCCESS! Works like a charm. B-E-A-UITFUL!
Meu Conselho
Not every repair goes off without a hitch. Deep breath, double check your work, even if you KNOW you did it right the first time. Troubleshoot, troubleshoot, troubleshoot. Then make the call. Sometimes its just the part.
Imagem de iPhone 6s Screen
iPhone 6s Screen
$54.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 9
Ao todo: 367
