Ir para o conteúdo principal
« Voltar para Todas as Histórias
Easy battery replacement
William Neuson -
MacBook Pro 15" Unibody Early 2011
Imagem da história
MacBook Pro 15" Unibody Early 2011 Battery Replacement
20 minutos
Moderate
Meu Problema
My MacBook battery began to fail and expanded to the point of temporarily deforming the aluminum near the trackpad.
Minha Solução
Using the iFixit Pro Tech Toolkit, I followed the instructions in the step-by-step guide. The battery charged in a few hours and proceeded to work fine.
Meu Conselho
In the event that the battery swells, remove the screws from the case closest to the failing section of the battery. Use a flat tool to carefully help the battery case out of the machine if the swelling is enough to deform the case.
Imagem de MacBook Pro 15" Unibody (Early 2011-Mid 2012) Battery
$69.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 111
