Introdução
Use this guide to replace a worn-out battery. If your battery is swollen, take appropriate precautions.
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Remove the two 7.4 mm Tri-point screws securing the battery to the upper case.
Use the attached plastic pull tab to remove the battery from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook Pro's SMC.
353 outras pessoas concluíram este guia.
34 Comments
I'd say this difficulty should be rated as easy, not moderate - it's well written and easy to follow, and documents one of the more simple procedures.
I think they rate it as "moderate" for needing to acquire the "Y" type screwdriver, but, (and here's a protip for first timers...) A small straight-blade actually fits and turns the screw as normal, with no need for special tools. :)
pyrodice -
