Ir para o conteúdo principal
« Voltar para Todas as Histórias
Replaced iPad Air Front Panel
maliawaddell -
iPad Air Wi-Fi
Imagem da história
  • Imagem #1
  • Imagem #2
  • Imagem #3
iPad Air Wi-Fi Front Panel Assembly Replacement
2 horas
Difficult
Meu Problema
My iPad had the ghost touching problem, where it just started freaking out and opening apps without being touched. My research pointed to a digitizer problem. I also had a small cracked screen area.
Minha Solução
I had mixed results. Eventually I fixed it. Getting the original screen off with all that adhesive was no joke. I also cracked my replacement screen trying to install the home button and had to order another. The home button still doesn't respond as well as the original. But I have a functioning iPad again! So I'll consider it a win.
Meu Conselho
Definitely order the replacement assy that has the adhesive and home button pre-installed. A razor blade and a blow dryer were my main tools used to remove the screen.
Imagem de iPad Air Screen Digitizer
$29.99
1 comentário
Sounds tricky, but glad you worked it out!
Cynthia Replogle - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 161
