Ir para o conteúdo principal
« Voltar para Todas as Histórias
Xbox One Restoration
Dash Wilson -
Xbox One
Imagem da história
Xbox One Fan Replacement
40 minutos - 1 hora
Moderate
Meu Problema
My Xbox One started to freeze up, warm up, and at some times, the fan started to scrape on the edges of it's bezel.
Minha Solução
The repair was a 9 out of 10 for me. The missing 1 is from one of the clips breaking, but that is not the tools' fault. Another thing is how locked on the fan was. However, it has not had any problems ever since I fixed it.
Meu Conselho
Once you get the fan off, do not just go to the sink and rinse it off. either get some compressed air, or use a waterpik as I did (I do not recommend my way of cleaning unless you have no compressed air). BE CAREFUL! If you are not careful, you will break a clip on something, guaranteed.
1 comentário
I find a lot of fans benefit from oil on the bearings; I use engine oil.
Anwar Shiekh - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 465
