Ir para o conteúdo principal
« Voltar para Todas as Histórias
Successful First-time iPhone 6 Battery Replacement
David -
iPhone 6
Imagem da história
45 minutos
Moderate
Meu Problema
The OEM battery had been reduced to less than 30% capacity and Apple refused to service the phone stating this was normal decline in battery life.
Minha Solução
Everything went well, with the one exception that I could not remove one of the 5 screws securing the cover over the display cable. Attempting to unscrew it with the iFixit-supplied screwdriver may have slightly stripped the screw. Ultimately had to remove and replace the battery without fully removing the display, but it all went smoothy after that.
Meu Conselho
Be patient with the battery adhesive. Despite the iFixit instructions I found it MUCH more productive to pull the adhesive only toward the bottom of the unit without moving to either side. You just have to give it time to loosen on its own while applying constant force to maintain tension, but it will come out and you won't have to use an iOpener or a hairdryer.
Imagem de iPhone 6 Battery
iPhone 6 Battery
$29.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 21
Ao todo: 125
