Ir para o conteúdo principal
« Voltar para Todas as Histórias
Nothing to it
Loose Drag -
MacBook Pro 13" Unibody Mid 2012
Imagem da história
MacBook Pro 13" Unibody Mid 2012 Hard Drive Replacement
20 minutos
Moderate
Meu Problema
My old 750 WD Black started acting funny, then the machine wouldn't start up. Luckily I was able to access the drive from my Hackintosh and remove all the files. I thought once the drive had been emptied I could reformat it, but it is toast. So much for WD Black. Replacing it with a Seagate SSHD 1TB, 8GB NAND because everyone's out of the 32GB NAND model.
Minha Solução
Smooth. Forgot I had to format the drive first. THought I could format it from online, but Apple as of 9/16 would only install Leopard from the web, and when the install dialogue box appeared, the drive didn't. So I had to pull the drive again and format it on my Hack again. Everything smooth. Careful with the screws!
Meu Conselho
Take it slow, dont drop any screws!
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Ao todo: 80
