Ir para o conteúdo principal
« Voltar para Todas as Histórias
Samsung Note 3 display replacement
Kevin Naquin -
Samsung Galaxy Note 3
Imagem da história
Samsung Galaxy Note 3 Display Assembly Replacement
10 minutos
Difficult
Meu Problema
Had to swap displays to transfer data from Note 3 with inoperative screen ->to new Note 3.
Utilized a display from surplus Note 3 to temporarily repair Note 3 with damaged digitizer.
Minha Solução
Worked wonderfully...until I got to removing the USB board.
It seems the USB board is secured with adhesive. The picture shows a small pointed tweezers lifting the corner. This method did not work, and I managed to fracture the corner of the USB board. The damage did not affect operation of the phone whatsoever.
Removal of the USB board was not required in my situation, as this was a temporary fix, only to extract the data from a damaged Note 3. The display was returned to the phone whence it came from.
Meu Conselho
You may want to mention a specific method of removing the USB board without damaging it.
Overall, I give this tutorial a 9.5 out of possible 10 points!
Thanks for the quality information!
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Ao todo: 224
