Ir para o conteúdo principal
« Voltar para Todas as Histórias
Fixing Nikon D3000 shutter release button error
danielec -
Nikon D3000
Imagem da história
How to fix Nikon D3000 shutter release button error
20 minutos
Easy
Meu Problema
Every time I tried to take a photo, the shutter release button error appeared and I had to retake the photo several times before the camera was able to take the photo properly.
Minha Solução
The repair was very easy to do when following these instructions.
Meu Conselho
I noticed that you don't have to remove the screw in the bottom of the battery place to remove the cameras bottom cover. I only removed the bottom cover, cleaned and lubed the gear wheel. When I tried the camera after reassembling it, it worked perfect. No more shutter release button error!
Imagem de Anti-Static Brush
Anti-Static Brush
$2.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 147
