Ir para o conteúdo principal
« Voltar para Todas as Histórias
Galaxy S3 Front Glass
pep073 -
Samsung Galaxy S III
Imagem da história
Samsung Galaxy S III Broken Front Glass Replacement
2 horas
Difficult
Meu Problema
Broke the front glass. I fixed it myself because I can, and because I refuse to be controlled.
Minha Solução
Very well. Everything works. The adhesive strip is tricky as it is the shape of the body and it sticks to fingers and there is a small amount of residue from the old adhesive still on the LCD but with the glass installed, it is covered.
Meu Conselho
DO NOT rush this fix. Take your time. DO NOT heat up the guitar pick. It renders it out of shape very quickly and useless. DO NOT use a hair dryer. Hire or get a heat gun. I didn't use a thermometer because I'm a pretty good judge of heat. But don't risk it if you're not sure.
Imagem de Spudger
Spudger
$3.99
2 comentários
"Because I refuse to be controlled and because I can"
Exactly me.
Po Lu - Responder Compartilhar
" I fixed it myself because I can" — like a boss! Thanks for sharing :)
Kay-Kay Clapp - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 8
Ao todo: 288
