Ir para o conteúdo principal
« Voltar para Todas as Histórias
Replaced Noisy Fan
rgroenhuyzen -
MacBook Pro 15" Retina Display Mid 2012
Imagem da história
  • Imagem #1
  • Imagem #2
MacBook Pro 15" Retina Display Mid 2012 Right Fan Replacement
45 minutos
Moderate
Meu Problema
The right fan began to "whine" after a 1 inch drop onto a desk. The noise was annoying especially in a quiet room.
Minha Solução
The repair was easy. I took my time as not to damage the delicate connectors. In all it took about 25 minutes. I followed the instructions on Ifixit and the repair went fine.
Meu Conselho
My Mac Book Pro is up and running again although the fan I replaced does make some noise as compared to the Apple OEM left fan. It is not noticeable unless you hold your ear to it. Be careful not to strip the small case screws and be very gentle with the Airport antenna connectors as well as the fan power cable connector.
Imagem de MacBook Pro 15" Retina (Mid 2012-Early 2013) Right Fan
$44.99
Imagem de Spudger
Spudger
$3.99
Imagem de T5 Torx Screwdriver
T5 Torx Screwdriver
$5.49
Imagem de P5 Pentalobe Screwdriver Retina MacBook Pro and Air
$5.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 113
