Ir para o conteúdo principal
« Voltar para Todas as Histórias
The right stuff made it easy.
GradyB -
iMac Intel 27" EMC 2546
Imagem da história
iMac Intel 27" EMC 2546 Adhesive Strips Replacement
30 minutos - 2 horas
Moderate
Meu Problema
The factory Seagate 3tb hd died.
Minha Solução
The iMac opening tool was perfect and the adhesive strips are top quality. The little blue tabs made it very easy to strip of the backing. They are also cut to fit perfectly, unlike the generic strips some companies sell.
Meu Conselho
I used an HGST enterprise 4tb drive. I've had great luck with the HGST drives. This machine has the Fusion drive. Disk Utility recognized the new drive and automatically reconfigured the Fusion to the new drive. No command line required.
Also used the OWC cable to enable the iMac to get drive temp to properly control fan speed.
Imagem de P2 Pentalobe Screwdriver iPhone
$5.99
Imagem de Plastic Cards
Plastic Cards
$2.99
Imagem de Magnetic Project Mat
$19.95
Imagem de iMac Opening Wheel
iMac Opening Wheel
$7.99
Imagem de Pro Tech Toolkit
Pro Tech Toolkit
$79.95
Imagem de Suction Handle
Suction Handle
$2.95
Imagem de iMac Intel 27" (2012-2019) Adhesive Strips
$29.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 7
Ao todo: 95
