Ir para o conteúdo principal
« Voltar para Todas as Histórias
iPhone 4S Rebuild
cpwittenberg -
iPhone 4S
Imagem da história
  • Imagem #1
  • Imagem #2
iPhone 4S Headphone Jack Cable Replacement
2 horas
Difficult
Meu Problema
My old iPhone 4S needed a new dock connector--it always thought it was docked, and was discharging itself and getting hot. When I replaced the dock connector, I broke the home switch cable. Then while replacing the home switch cable, I broke the secondary mic off the headphone jack.
Minha Solução
Due to all my mistakes, I essentially had to do a full disassembly, replacing the headphone jack/secondary mic/volume button/hold button flex AND the home button switch. I have worked inside the iPhone 4S a few times, but never had to disassemble so much. The repair succeeded perfectly, thanks to experience. But it felt like Mission Impossible.
Meu Conselho
Don't try replacing the iPhone 4S headphone jack assembly unless you have some experience and a good magnifier. Also, always read the comments for tips about difficult-to-see items, such as the secondary mic which is tethered to the headphone jack.
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Ao todo: 381
