Ir para o conteúdo principal
« Voltar para Todas as Histórias
Modern Watch Repair
webmersh -
iPhone 4
Imagem da história
  • Imagem #1
  • Imagem #2
  • Imagem #3
iPhone 4 Rear Panel Replacement
2 - 5 minutos
Easy
Meu Problema
Iphone 4S smashed front and back; dropped in the locker room.
Minha Solução
Went pretty well, took longer than I expected. Had to go backwards a bit because cable ribbons from new display were tricky to route without crimping. And the corner screw by the earphone jack took a lot of patience.
Meu Conselho
Be super careful when mounting the new display that the cables come through straight and clean or there won't be enough slack to plug them in!
Was so happy to see the apple after the procedure!
And the white button is an unexpected trophy: proof that it's been rebuilt.
Imagem de iPhone 4S Screen
iPhone 4S Screen
$34.99
Imagem de iPhone 4S Blank Rear Glass Panel
$19.99
Imagem de iPhone 4S Battery
iPhone 4S Battery
$18.99
Imagem de iPhone 4 Battery
iPhone 4 Battery
$11.99
Imagem de iPhone 4 GSM OEM Used Rear Glass Panel
$6.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 10
Ao todo: 61
