Ir para o conteúdo principal
« Voltar para Todas as Histórias
MacBook Pro surgery
Enrico Barbieri -
Electronics Skills
Imagem da história
  • Imagem #1
  • Imagem #2
  • Imagem #3
How to Apply Thermal Paste
5 - 20 minutos
Moderate
Meu Problema
My MacBook fans will always run at max speed while using heavy apps like VMware Fusion. The situation was critical mainly because of the noise of fans running at 6200rpm
Minha Solução
The repair went well... I opened the MacBook without any particular issue thanks to the heat sink replace guide provided by iFixt. Just moving really slowly because I was afraid of broking some contacts and mess up everything...
Meu Conselho
Repair is basically easy even if you need to disassemble half of your MacBook... Watch out for cables and plug while you put logic board in place... If it does not fit perfectly there are some cables on your way
Imagem de iFixit Thermal Paste
$24.95
Imagem de Arctic Silver ArctiClean
$11.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 13
Ao todo: 68
