Ir para o conteúdo principal
« Voltar para Todas as Histórias
Not Enough Space
Lojeck -
MacBook Core Duo
Imagem da história
  • Imagem #1
  • Imagem #2
MacBook Core Duo Hard Drive Replacement
5 - 30 minutos
Easy
Meu Problema
I had a hard drive with 160 GB of space. I do a lot of graphic art and multimedia work and my disk space was full and it began a kernel panic that would cut my machine off in the middle of projects. Grrrr!
Minha Solução
The repair was straight forward and simple :)
Meu Conselho
Make sure to download a hard drive cloning program like SuperDuper!
Also, if you disconnect your battery connector from your logic board make sure to plug it back in. I forgot and powered up! Luckily the connector went back into place when I closed it back up...whew!!
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Ao todo: 115
