Ir para o conteúdo principal
iView-776TPCII Digitizer Replacement
O que você precisa
    1. iView-776TPCII Digitizer Replacement, Rear Panel: passo 1, imagem 1 %32 iView-776TPCII Digitizer Replacement, Rear Panel: passo 1, imagem 2 %32 iView-776TPCII Digitizer Replacement, Rear Panel: passo 1, imagem 3 %32
      • Before disassembling your device, make sure that the power is completely turned off.
      • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
      • The clips may take some pressure before releasing.
      • Continue around the entire device until all of the clips have been released.
      Pergunte ao FixBot
      Comentar
    2. iView-776TPCII Digitizer Replacement: passo 2, imagem 1 %32 iView-776TPCII Digitizer Replacement: passo 2, imagem 2 %32
      • Use a spudger to carefully free the speaker from it's housing on the back panel.
      • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
      • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
      Pergunte ao FixBot
      Comentar
    1. iView-776TPCII Digitizer Replacement, Battery: passo 3, imagem 1 %32
      • Insert the flat side of the standard spudger underneath the battery and use a prying action to loosen the glue holding it to the digitizer.
      • Do this all around the battery until it comes off.
      • The glue is strong, so some force may be required. However, be careful not to apply so much pressure that the battery bends or breaks.
      • At this point, do not attempt to fully remove the battery, since it is still connected to the motherboard.
      Pergunte ao FixBot
      Comentar
    2. iView-776TPCII Digitizer Replacement: passo 4, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Use the Portable Soldering Iron tool to heat the leads coming from the battery to the motherboard, thereby breaking the connection.
      • For help on soldering, refer to the iFixit "How To Solder and Desolder Connections" technique guide as necessary.
      • Once heated, use tweezers to pull the wires free from their connections.
      • To ease reassembly, take note of which wire went to the positive and negative terminals.
      Pergunte ao FixBot
      Comentar
    1. iView-776TPCII Digitizer Replacement, Wi-Fi Antenna: passo 5, imagem 1 %32 iView-776TPCII Digitizer Replacement, Wi-Fi Antenna: passo 5, imagem 2 %32
      • Detach the end of the Wi-Fi antenna from the tape on the edge of the shell.
      Pergunte ao FixBot
      Comentar
    2. iView-776TPCII Digitizer Replacement: passo 6, imagem 1 %32
      • Use the Portable Soldering Iron tool to heat the lead coming from the Wi-Fi antenna to the logic board, thereby breaking the connection.
      • Once heated, use tweezers to pull the wire free from its connection.
      Pergunte ao FixBot
      Comentar
    1. iView-776TPCII Digitizer Replacement, Camera Assembly: passo 7, imagem 1 %32 iView-776TPCII Digitizer Replacement, Camera Assembly: passo 7, imagem 2 %32
      Heavy-Duty Spudger
      • The camera module is located in the upper-right corner of the tablet.
      • Loosen the edges of the black tape covering the camera using the heavy-duty spudger.
      • Use the freed edges of the tape to gently remove the camera assembly from its plastic housing.
      • The camera assembly will still be connected to the rest of the device via a ribbon cable. Take care so as not to tear this connection.
      Pergunte ao FixBot
      Comentar
    2. iView-776TPCII Digitizer Replacement: passo 8, imagem 1 %32 iView-776TPCII Digitizer Replacement: passo 8, imagem 2 %32
      • Use tweezers to lift the cover off the top of the camera's ZIF adapter.
      • When reassembling the device, be sure to fully secure the ribbon cable from the camera back into the ZIF adapter.
      • Pull the assembly away from the motherboard with a set of tweezers to prepare for desoldering.
      Pergunte ao FixBot
      Comentar
    3. iView-776TPCII Digitizer Replacement: passo 9, imagem 1 %32
      • Use the Portable Soldering Iron tool to heat the leads coming from the camera assembly to the motherboard, thereby breaking the connection.
      Pergunte ao FixBot
      Comentar
    1. iView-776TPCII Digitizer Replacement, Motherboard: passo 10, imagem 1 %32 iView-776TPCII Digitizer Replacement, Motherboard: passo 10, imagem 2 %32 iView-776TPCII Digitizer Replacement, Motherboard: passo 10, imagem 3 %32
      • Remove the three 2.2mm Phillips head screws using a screwdriver to loosen the motherboard from the shell.
      • Check "Screwdriver Best Practices" as needed for help on how to properly use a screwdriver with your device.
      Pergunte ao FixBot
      Comentar
    2. iView-776TPCII Digitizer Replacement: passo 11, imagem 1 %32 iView-776TPCII Digitizer Replacement: passo 11, imagem 2 %32
      • Use the 45 degree tweezers to lift the black section of the digitizer ZIF adapter to release the ribbon. Gently pull the ribbon cable out of its socket.
      • When reassembling the device, be sure to fully secure the ribbon cable back into the ZIF adapter.
      Pergunte ao FixBot
      Comentar
    3. iView-776TPCII Digitizer Replacement: passo 12, imagem 1 %32 iView-776TPCII Digitizer Replacement: passo 12, imagem 2 %32 iView-776TPCII Digitizer Replacement: passo 12, imagem 3 %32
      • Use the 45 degree tweezers to lift the black section of the LCD ZIF adapter to release the ribbon. Gently pull the ribbon cable out of its socket.
      • The motherboard is now separated from the digitizer and front panel and can be safely removed from the device.
      Pergunte ao FixBot
      Comentar
    1. iView-776TPCII Digitizer Replacement, Digitizer: passo 13, imagem 1 %32 iView-776TPCII Digitizer Replacement, Digitizer: passo 13, imagem 2 %32 iView-776TPCII Digitizer Replacement, Digitizer: passo 13, imagem 3 %32
      • Insert the plastic opening tool between the digitizer and the screen. Use a prying motion to loosen the digitizer from its plastic case.
      • If you find it hard to separate the two components at first, try to use another plastic opening tool for support.
      • Continue moving along the edge of the digitizer until it is fully separated.
      Pergunte ao FixBot
      Comentar
Conclusão
Cory Gratzer
Membro desde: 09/16/15
586 Reputação
Autoria de 5 guias
Equipe
IUPUI, Team 2-2, Baechle Fall 2015 Membro de IUPUI, Team 2-2, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G2
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 25
Ao todo: 981
