Ir para o conteúdo principal
iView-776TPCII Battery Replacement
O que você precisa
    1. iView-776TPCII Battery Replacement, Rear Panel: passo 1, imagem 1 %32 iView-776TPCII Battery Replacement, Rear Panel: passo 1, imagem 2 %32 iView-776TPCII Battery Replacement, Rear Panel: passo 1, imagem 3 %32
      • Before disassembling your device, make sure that the power is completely turned off.
      • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
      • The clips may take some pressure before releasing.
      • Continue around the entire device until all of the clips have been released.
      Pergunte ao FixBot
      Comentar
    2. iView-776TPCII Battery Replacement: passo 2, imagem 1 %32 iView-776TPCII Battery Replacement: passo 2, imagem 2 %32
      • Use a spudger to carefully free the speaker from it's housing on the back panel.
      • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
      • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
      Pergunte ao FixBot
      Comentar
    1. iView-776TPCII Battery Replacement, Battery: passo 3, imagem 1 %32
      • Insert the flat side of the standard spudger underneath the battery and use a prying action to loosen the glue holding it to the digitizer.
      • Do this all around the battery until it comes off.
      • The glue is strong, so some force may be required. However, be careful not to apply so much pressure that the battery bends or breaks.
      • At this point, do not attempt to fully remove the battery, since it is still connected to the motherboard.
      Pergunte ao FixBot
      Comentar
    2. iView-776TPCII Battery Replacement: passo 4, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Use the Portable Soldering Iron tool to heat the leads coming from the battery to the motherboard, thereby breaking the connection.
      • For help on soldering, refer to the iFixit "How To Solder and Desolder Connections" technique guide as necessary.
      • Once heated, use tweezers to pull the wires free from their connections.
      • To ease reassembly, take note of which wire went to the positive and negative terminals.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Cory Gratzer
Membro desde: 09/16/15
586 Reputação
Autoria de 5 guias
Equipe
IUPUI, Team 2-2, Baechle Fall 2015 Membro de IUPUI, Team 2-2, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G2
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 24
Ao todo: 1,199
